Yeah, it happens when I turn on the windshield de-fogger (cause that's all I use). I haven't tested the other fan settings, but i'm sure it probably does the same thing?numbnuts240 wrote:my idle will go up if i turn on just the windshield de-fogger, but it won't fluctuate like that. it definitely isn't normal.
Oh s***. . . I DO have Air conditioning. . . Is that why? It just doesn't seem normal why the engine's RPM's always jump from 800-1100 all the time (while the de-fogger is on). Only when I shut off the de-fogger, my RPM's stays at 800.blacksrjdm wrote:Sounds like either all of you have air in the systems, or, you are seeing the rpms go up slightly from the A/C comp turning on with the defrosters.
Alright thanks a lot. But is my RPM's bouncing range too extreme? As you've mentioned, the A/C compressor kicks in, causing the RPM's to increase and decrease, but by 300 rpm's? That seems like a tad too much doesn't it?greencar wrote:yes when you defrost, it kicks in the A/C compressor, and basically runs the A/C. air from the blower motor is blown over the evaporator to prevent the fogging of your windows
-Dan
Alright thanks a lot for the response. Hmm I should have known, 240sx abnormalities are the OEM stock normality. . .greencar wrote:seems normal. mine goes to 1200, but i dont have the ac belt on currently. so it doesnt have a load.
-Dan
