Hmm. . . I need your guys' opinion on this KA turbo setup.
Jagstang
Car: 1995 S14 w/ Kouki S14 SR20DET
After months of deliberation, I have decided that I might go turbo on my KA, and I was wondering if it were possible to leave the stock S14 radiator if I ran an oil cooler, and a lower temp thermostat?
Also, this is what I might be running for my KA-T setup (local guy is selling this setup, all of it has under 2000 km's of use), I need your guy's opinion on how good it would be, and how reliable it would turn out.
* Enthalpy tuned ecu (94 octane required)
* Jecs injectors - running at 465cc (remanufactured)
(injectors were redone to 425cc)
* Tomei FPR/Tomei fuel rail adapter and fitting with goodridge ss braided lines and earls -an fittings ( set at 49.5psi )
* new bosch o2 sensor
* NGK BKR7EIX-11 Iridium spark plugs (gaped to 0.032)
Jdm Sport turbo journal bearing (oil and water cooled)
* Turbo - t25/t28 hypbrid
(SPECS : Compressor Specs :
1.70" Compressor Inlet
1.685" or 42.81mm inducer
2.362" or 60.00mm Major
Compressor .80 A.R.
M24 T2 Compressor Housing
Turbine Specs :
1.850" Exducer
Turbine .86 A.R.
2.090" or 53.10mm Major
1.820" or 46.25mm Minor
* turbo to intake adapter
* N60 MAF (pigtail will be included but will need to be wired up)
* SS autochrome Front mount intercooler 30.5"x 12"x 3" (core measures 23"x12"x3")
* Togue Factory Sr20det Hotpipe for greddy bov slightly modded to fit for KA. 2.25" hot pipe to intercooler , 3" cold pipe into the intake manifold
* Greddy RZ BOV
*SS bottom mount style turbo manifold (no brand)
*SS 3" turbo elbow (no brand)
*SS 3" downpipe (no brand)
* -3an ss braided turbo oil line with -an adapters ( feed comes from oil pressure sensor location )
* greddy oil cooler adapter with thermostat
* goodridge -10an oil lines with goodridge and earls -10an fittings
* 13 row oil cooler
* Max remote oil filter relocation (uses newer Nissan oil filters, ka24de filters to not fit) (says on Part shop max site)
*Cusco Oil catch can
*modified oil pan for oil return -10an fitting with ss braided hose and -an fittings
*also includes intake manifold ( butterflies removed).
Help would be greatly appreciated, thanks in advance.
simmode1
Car: Red '95 S14
Have a mod move this to the KA-T forum for more informative responses...
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
I personally don't like those skinny alu and plastic rads if you are going turbo. I'm not saying it won't work with those supporting mods but a nice dual pass is good insurance or a nice copper rad.
As long as the tune it good it sounds like a beast turbo setup.
Lobo240sx
Car: 1991 Nissan 240sx Coupe SR2.35DET Redtop Build
Get a bada$$ aluminum radiator with some cooling fans. I don't know where you live but in Texas you can't be bsing around with the heat. Good insurance for the engine.
jeremy242
Car: 89 240sx
why n60? might as wel get the n62 one time and be able to support higher power goals.
Gabes13
Car: rb20det s13
A larger radiator can dissipate more heat because of its size, but if your oem radiator is in good condition, and you have the clutch fan and shroud, you'll be fine. An oil cooler, like mentioned, would be very beneficial also.
