Hmm. . . I have a base model S14 and I think I have a. . .
Jagstang
Car: 1995 S14 w/ Kouki S14 SR20DET
I have a base model S14 SE and I think I have a factory Viscous Limited Slip Differential. . . But what confuses me is the fact that I though all base model S14's came with an open differential? I took this video to show you guys.
Btw, I had the ebrakes down, and the car was in neutral.
http://www.youtube.com/watch?v=3NyPcJG-adM
So is that a VLSD?
P.S. My car is a pure S14 basemodel with 4 lugs, no ABS, no rear stock sway bars, etc. I have heard of base model S14's coming with VLSD's. . But it was a package that included the ABS and the VLSD. But I don't have ABS. . .?
Modified by Jagstang at 1:45 PM 10/11/2009
jbracy7
Car: 94 GTS TYPE-M in a dozen pieces
no ur just lockin up ur rears with the e-brake
Jagstang
jbracy7 wrote: no ur just lockin up ur rears with the e-brake
Sorry, but I had the ebrake handle down. And the car was in neutral?
Dire91
Car: 1997 Nissan 240sx SE
I've always wondered this too, I have a 97' SE and can't tell the difference.
Jagstang
Dire91 wrote:I've always wondered this too, I have a 97' SE and can't tell the difference.
Yes, me too brother, me too. . .
Thaddeus
Car: 1998 240SX se 1984 Porsche 944
You should have someone apply just a little resistance to the tire you are not spinning by hand, I think you will find that it will not rotate while the other will. I don't believe your car came with a LSD. Or just go do some burnouts in some gravel and find out that way.
Wretched
Car: 93' Hatch
Just look for the bright orange sticker on the diff. Or go do a big smokie and see if you leave two marks. The reason the tires are moving is b/c when it's in neutral there is still a little bit of drag in the bearings causing power to be transfered to the rear. It's hard to explain and I haven't cracked open a transmission in at least a year. Anyway, check the diff for the sticker, someone may have already swapped the diff.
Jagstang
Thaddeus wrote:You should have someone apply just a little resistance to the tire you are not spinning by hand, I think you will find that it will not rotate while the other will. I don't believe your car came with a LSD. Or just go do some burnouts in some gravel and find out that way.
Hmm alright, before doing the burnouts, i'll try your theory first (getting someone to go to the other wheel, and apply resistance).
Wretched wrote:Just look for the bright orange sticker on the diff. Or go do a big smokie and see if you leave two marks. The reason the tires are moving is b/c when it's in neutral there is still a little bit of drag in the bearings causing power to be transfered to the rear. It's hard to explain and I haven't cracked open a transmission in at least a year. Anyway, check the diff for the sticker, someone may have already swapped the diff.
I tried looking for the bright orange sticker, and could not see anything (mainly due to the fact that it's extremely dirty with grime, oil, etc)
Alright, and about your neutral bearings explanation, should I try spinning it in gear 1?
ProjectGarage
Car: Hehehe.
Are you the original owner? Maybe the old owner put a vlsd in...
AZ89two4Tsx
Just rev to about 5K and dump the clutch in first gear.
Are you worried about breaking something? lol
It's really not that difficult of a test dude.
Jagstang
ProjectGarage wrote:Are you the original owner? Maybe the old owner put a vlsd in...
I'm not the original owner, i'm the second owner... But the original owner gave me all the receipts since 1995, and there's nothing that mentions a differential swap. He only took the car to the dealership. . .
AZ89two4Tsx wrote:Just rev to about 5K and dump the clutch in first gear.
I know it's not, but where I live, there isn't any places to test it out :| I'll see if I can scope a hidden and quiet area.
Modified by Jagstang at 3:24 PM 10/11/2009
s14derrick
Car: 1995 nissan 240sx
just search 240sx decoder. and look at the vin and mid decoders,. it will tell you what your car should have came with from the factory
anti_flag_army
Car: 91 Miata, 90 240sx coupe
You want the easiest way to do it without a burnout, jack up the rear so both tires are off the ground. Take off the e brake, and rotate one tire, if the other tire goes the same way, its an lsd, if it spins the other way its an open
Jagstang
s14derrick wrote:just search 240sx decoder. and look at the vin and mid decoders,. it will tell you what your car should have came with from the factory
Oh man thanks a lot. I just checked it out with this site
http://my240.epijunkie.com/240...oding
And the 18th digit on my cars model ID (Drive System Options) is "A" which stands for a "Viscous Limited-Slip Differential (VLSD)". Sweet thanks so much, now I know for a fact that I have VLSD.
Jagstang
anti_flag_army wrote:You want the easiest way to do it without a burnout, jack up the rear so both tires are off the ground. Take off the e brake, and rotate one tire, if the other tire goes the same way, its an lsd, if it spins the other way its an open
Yeah, if you look at the youtube video I posted, that's my car, and that's exactly what i'm doing. Thanks.
anti_flag_army
Oh i see, im at work and couldnt see the video. Then just have someone hold the wheel like it was stated earlier
Dazzla
You have a LSD...as do I. My car is a exact replica of yours.
If you don't agree then just do a quick burnout in your driveway...its not a big deal lol Rev it up and drop the clutch...if you have 2 tire marks, you get your answer lol
Jagstang
Dazzla wrote:You have a LSD...as do I. My car is a exact replica of yours.
Yeah yeah, I just went out to do a burnout with my fellow nico naught Asoomal, and he did a 25 second brake stand in my car, and yup, two fat marks.
ThuG LyFe
Car: 95 S14
if you don't have abs i can tell you that you don't have the factory vlsd. if you do have one someone must've installed it before the car was yours.
although base models could be ordered w/ abs/vlsd package i still believe that you either got both of them or nothing.
Jagstang
ThuG LyFe wrote:if you don't have abs i can tell you that you don't have the factory vlsd. if you do have one someone must've installed it before the car was yours.
Well, I checked the model ID of my vehicle, and it clearly says I have a stock VLSD. I know what you mean tho, weird, it should have included an ABS system.
Modified by Jagstang at 8:26 PM 10/11/2009
240sx_dad
Car: 1991 Nissan 240sx
open differentials can leave two black marks as well, the gears just have to catch at the right time
Jagstang
240sx_dad wrote:open differentials can leave two black marks as well, the gears just have to catch at the right time
What? Hmm, interesting, i've never heard of that. Well i know for a fact it's a VLSD, first the tires spinning perfectly together (when the car is jacked up in the back), secondly, reading the model ID, and third the brake stand. I highly doubt an open differential would fluke out on the first and last tests?
Modified by Jagstang at 8:39 PM 10/11/2009
jeff420
Car: too many to fathom
yea its a vlsd. open diffs the opposite tire would have spun the opposite wheel. of course you already know this.
-RJ-
Car: S13 Convertible, 99 Frontier, 03 Sportage, 96 Protege
jack up the rear end and spin a wheel. The other wheel shoud move the same way
Jagstang
-RJ- wrote:jack up the rear end and spin a wheel. The other wheel shoud move the same way
If you look at my first post, I posted a youtube link (which shows what you've just said). That's my car btw.
asoomal
Car: 2001 Subaru Impreza L 5MT (Daily)
1992 Nissan 240SX SE 5MT w/HICAS (Being restored)
It's got VLSD.
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
abs and vlsd were offered independently of each other. so it is, in fact, possible to have one without the other.
Dazzla
hmm...I have a VLSD too according to that link you posted. Mine is literally a sister car to yours lol
Jagstang
Dazzla wrote:hmm...I have a VLSD too according to that link you posted. Mine is literally a sister car to yours lol
haha yeaa!!! Sweet man, good to know, seeing how you have modified your car more than mine, i'll keep my eyes peeled on ya. You're car is a futuristic S14 guinea pig for me
