Hmm. . . Caster question. . .
Jagstang
Car: 1995 S14 w/ Kouki S14 SR20DET
Hey guys, I got into a little curb damage 2 days ago (banged my two front wheels against the curb), and I got one of the tie rods changed today (bent after the accident), and then got it aligned. Now while driving, the car pulls to the right.
The front left wheel is set on 6.3 degrees, and the front right is set on 4.1 degrees. . . The shop who installed the tie rod, and done the alignment said that it's pulling to the right, and for reasons of either the spindle, or control arm.
After getting home, I checked the tension rod bushings, and both of them are leaking.
Now my question is, can I still drive my car without any tire wear etc? And will fixing the bushings fix the pull?
Let me know, thanks in advance.
shanelach
Car: N/A
Caster will cause the car to pull towards the most negative side. Basically, if those numbers you posted are your caster degrees, that would explain why you are pulling I would think.
Jagstang
shanelach wrote:Caster will cause the car to pull towards the most negative side. Basically, if those numbers you posted are your caster degrees, that would explain why you are pulling I would think.
Yeah, the right wheel is -2 degrees less than the right. And yes, the car pulls to the right. But my question is, would changing the leaking OEM bushings to nice aftermarket ones fix the negative camber on the right wheel? Or do I need to also replace the tension rods?
P.S. The accident was both my front wheels hitting the curb head on.
Modified by Jagstang at 6:06 PM 12/5/2009
E7-S14
Car: ess 14 foo!
tension rod bushings leaking?
Jagstang
E7-S14 wrote:tension rod bushings leaking?
Yes, the tension rod bushings are leaking. But I was just wondering if I change the leaking bushings, will it fix the caster to the 6 degree zone?
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
I dont think the bushing are going to help that much, unless there is a lot of play.
I think you should replace the LCA on that side, along with the tension rods (because its easier then bushings.
mrgreeneyes
Car: ///M5
Parted Out Built S13 Coupe
it should.
the core problem:
your car is high enough that a curb can access your tires.
slam your car. dont run into curbs. fix tension rods.
nifares240
Car: 1993 240sx Black-Project Car, 1993 240sx Red-SOLD, 1994 Sentra, 2004 Nissan Sentra SE-R SPEC V-Daily, 1999 Toyota Camry
you should change your LCA, tension rod, and tie rods (if damage). go to auto parts warehouse, they sell the OEM ones with new bushings for freee shipping. its a lot easier than changing bushings.
and stop hitting curbs.
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
A bent strut can also cause bad caster. More then likely though your tension rod or control arm is bent. Also caster will not cause any uneven wear on your tire, it will only cause the pull.
Dazzla
whats with the photochop sig dude
SirSilvia
Car: Sold both my babies
wait, tension rods can leak? there's fluid in the bushing or something? I replaced both of mine right off the bat after this... It gave me an excuse to upgrade.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
They are are filled with some sticky gel, much like the OEM motor-mounts.
OP did you fix this yet?
Bumnah
Car: 1992 240SX, black. Bone stock.
mrgreeneyes wrote:it should.
the core problem:
Then you can just every other part of your car too?
SirSilvia
OutToWinPAHC wrote:They are are filled with some sticky gel, much like the OEM motor-mounts.
huh, did not know that replaced mine early on wit solid, adjustable ones.
Jagstang
I haven't fixed it yet (due to all my final exams taking up my time). But i just finished my last final exam yesterday, and I will be ordering these to fix the problem.
http://www.frsport.com/Circuit....html
Should be what I need to fix the caster problem.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
It will help, but I think I would do a new LCA too.
SirSilvia
Those are kinda what i installed, egay brand, but haven't had a problem in about 4 years, so w/e.
