nothingstoofast wrote:i have a maxima 90 se....... i'd be willing to challenge the celica in the twistes. granted the 90's maxima's were defenetly not as fast as the 95 and up but the suspenstion was a bit more aggressive. in my car i have front rear drop springs, koni struts, front / rear sways, my own custom built front rear strut bars (did both for all of 20$). the only thing i dont have yet is subframe connectors. oh and i sit on toyo proxy t1-s's. oh yea i ate a 02-03 GTS alive...... i'm not sure if your gt is any better in handling
Perhaps the celica would smoke me stock for stock, but we shall never know:hiding:
There is a point where my car will go from understeer to oversteer when I'm in the sweet spot of the motor in 2nd and 3rd gear in the twisties. Then there's also that point(before upgrading suspension) where the back end has a mind of it's own:rolleyesMinisterofDOOM wrote:I took the '04 out and pushed her a bit yesterday. I did notice a bit of understeer while under throttle. Nothing severe enough to cause problems, just enough that I had to adjust a bit to compensate. At times, partially due to torque steer (yeah...it's hard to explain), it almost feels like the car is oversteering like a RWD while cornering under very large amounts of throttle. Considering the amount of torque steer produced by this car, I am glad that Nissan didn't make the same mistake with the Maxima that Acura did with the TL's front LSD.
