HMM, ANOTHER HARNESS QUESTION
oversteer180
Car: 1990 Silver 240sx
Ok, we just recieved the ca18det harness we had ordered a few weeks ago. Im selling my motorset in a few weeks, and with all the confusion about harnesses/ecus matching etc. i just wanted to make sure I had the right setup for my buyer.
I have an 79 ECU,Is my ecu a 5 speed ecu? I for some reason have a dropping resistor down towards the plugs you have to rewire, doesnt this mean its an auto harness? Will this work with the 5 speed transmission? I have a 5 wire DSM dropping resistor pack..how do I wire it in to the Ca dropping resistor plug?
I just want to double check these things out before I sel it.
89'ClubK's
Car: 89' Nissan 240SX
The Automatic has two dropping resistors. One, like a 5 speed, is on the passenger side near the main harness that you rewire. The other is on the driver side by the MAF. In order to make the DSM one work, you'll have to get the diagram for the CA main harness & the diagram for the DSM dropping resistor. Match up the colors with the correct codes, and splice them together.-- 79 is a 4sp. ECU, 98 is for a 5 sp.--*BTW* if you choose to sell this ECU, I need a spare one for my 4sp. car. Best of luck!
oversteer180
**** that pisses me off. Well i need to get this worked out before I sell it. I heard the auto ecus work for the 5 speed as well. Can anyone confirm this?
kahlistrophic
Car: 92' 240sx base
any info on where i can order a ca18det harness? The 5spd dropping resistor is on the air box and Maf. Need a harness ASAP.
oversteer180
eh, anybody have some answers? I know of an importer that can get them, he charges $360 shipped for the ecu and harness however. He does have 2 in stock.
oversteer180
anybody know if the auto ecu (79)and auto harness will work with the 5 speed?
kahlistrophic
Car: 92' 240sx base
can you gimme the importers info? please email me at [email protected]. Why dont you use the dsm dropping resistor finding the wiring for both the ca and dsm resistor? As for the ECU im a noob.
oversteer180
89'ClubK's
I don't know how well it would work, as the auto ECU won't allow you to rev like a 5sp. You may be able to use the harness, but you'll have wires left over. The harness would include wires that go to the transmission.The Automaic is ALOT more complicated!
BLKTOPS14SR
Car: 1998 Nissan 240SX SE Kouki
1971 Buick Skylark 455Buick big block
1970 Cutlass Holiday Coupe
2002 Ford F-150 XLT
1972 Chevy Cheyenne
From what I've been told you can use an auto ecu with manual, but not manual with auto. And Pat the ECU doesn't control your engine RPM's. Your auto trans does that! Our friend with a KA-T was running a Auto ECU from a 95 in his 91 and it ran fine. He ran this until his reflash unit got back to him. About a month or more without any issues! The Aussie's are a really good connection for CA parts as they have really helped my brother (89'ClubK's) out alot on hard to find goodies!!
