compactfean »
https://forums.nicoclub.com/compactfean-u148941.html
Sun Dec 11, 2011 4:35 pm
If its a 6 bolt pattern in sets of 2' s than yes its s direct swap. If its 5 bolt, than j30 axles are needed. if it's 6 bolt star, you need rather a driver side z32 300zx tt axle or a r32 skyline driver side axle and q45 axle ( if that's the case hubs are required) if it comes with axles you should be fine. (unless the axles are 30 spline, than you will need hubs) that pretty much goes for all r200v diff swaps.
