HLA seals
pwpbdwdb2
Car: 1996 Q45
I have a 1996 Q45 Infiniti
Dose any one know where I can find the seals for the HLAs
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
01 B15 Sentra (Daughter's)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
welcome. your question is very direct, but intrigues me. what makes you want to replace the HLA o-rings?
you said seals which i took generically. they have very thin o-rings.
pwpbdwdb2
Car: 1996 Q45
I was changing valve seals and head gaskets and had to pull HLA's most of the exhaust side HLA's were falling apart.
I was able to find 1mm wide X 15mm ID chemical O-Rings from Master Carr with a 450 degree rating.
3Q Jay
Car: 94 Q45a
95 Q45a (sold)
97 Q45t (sold)
Also Mine...
2010 A6 Avant
1977 F-150 (460!)
they do get brittle, but unless disturbed don't seem to be an issue. your scenario is very plausible, good you found some. Note that the HLA diameter is 16.98mm, so your 15mm o-rings will have a slight stretch, may be ok.
please give back to the community with copious pictures and your experience with replacing the o-rings.
you may find it useful to pre-soak the HLAs and pump them up by submerging in clean oil prior to re-installation.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Yeah this is definitely something a lot of people have encountered when rebuilidng heads.
Here's a couple thread from back in the day...
vh-hydraulic-lash-adjusters-o-rings-t486117.html
question-about-hla-s-t250062.html
