SUB ZERO CAR FANATIC »
https://forums.nicoclub.com/sub-zero-car-fanatic-u53284.html
Sun Jul 29, 2007 4:25 am
Thanks for a quick response.I was worried i wouldnt get through to you for a while and i have got to get this thing together as soon as possible. these are the parts that were replaced on motor: timing chains,guides,tensioners,oilpump chain,sprockets,etc. Let me rephrase rebuild,if your going to take the time to help me i need to start from the beginning i guess. I have a base model 1993 Q45,which i have been restoring for the past 2 years. BUILD DATE=1/93 When i purchased the vehicle it had been setting a while,i paid $600 for the car.The man i bought it from had the nissan dealership here in fairbanks(as we dont have a infiniti dealership here in Alaska) put it on the rack and check it out.They pulled the oil pan and found one of the rod cap bearings spun,worn out.They discovered the oilpan had a hole in the corner of it so it was losing oil and he obviously didnt keep a check on the oil level.Nissan told him it would be $4500-$5200 to have it rebuilt.He didnt want to spend the money to have it fixed and still owed $4000 on the car. long story short i did some work re-modeling the guys house for trade on the car.I got it home with plans on rebuilding the engine.After talking to a few shops here and seeing how expensive and hard it would be to get parts,a local shop refered me to someone local who could order me a low mileage motor for my Q and said id be better off in the long run.so they ordered the engine once i got it here it was to fairbanks alaska total cost was$1400,and the engine was said to have around 30-40k miles on it(from japan) and it would bolt wright in.I didnt know alot about Q45'S at the time,so when it got here i found out it was out of a 94 model .I was told it would work with no modifications,then i found out the CAS was different and my wiring was different and etc. So the place where the engine came from said if id do the labor of swapping the heads from my 93 motor to the 94 motor that would solve everything and they would pay for the Gasket set needed for doing the head swap.So i agreed and thats what i did. i havent had the lifters out of their place but the heads were up on their sides and turned over etc. when the heads were cleaned.my concern is after reading the manual,that the lifters might need to come out to prime them and get air out even though they werent actually out and on their side is this necessary or can i do the several warm/cold starts like you stated in one of the posts? also i have already installed all the new timing parts and put on front engine covers.also when the motor is set to TDC like the manual stated everything seems correct but the CAS ,(i dont think) is in the correct posistion.I have cover off CAS so you can see the opening notch on the rotor looking part that is supposed to align up directly to the left with the black plastic part in the 9:00 posistion. I THINK ITS SUPPOSED TO POINT TO 9:00?? BUT MINE IS POINTING TO ABOUT 10 or 11:00! AM I CORRECT? CAN I LOOSEN CAS SCREWS AND TURN IT SO THE NOTCH POINTS AT 9:00?? PLEASE HELP. MUCH APPRECIATED!!
