DAEDALUS wrote:And what work have you done, what pieces did you leave out?
Just did chain guide replacement in December. The 2 beefy nylon guide pieces that go on the tension side bolts were left out so I opened the front cover to put them in. Also have recently done new plugs. (In addition, have done 8 new injectors, knock sensors, all plenum hoses, fuel filter, trans cooler, cleaned TB/plenum/intake, water pump and tstat, new tokicos, upper links since I've owned the car)
My guess is either they bled down and the #2 cylinders HLAs have air in them or some gunk was dislodged and is clogging a port. Did not see evidence of sludge problem when cover was off and know the history on this car- regular oil changes. If it's air, any way to bled them while they are still in the engine? Byron says you have to pull the cams to get them out of the heads.
Still can't figure out why the noise has moved from one cylinder to another.
Modified by 3rd Q at 10:07 AM 1/21/2005
