Keep the 272's, lose the bc springs and go with these http://www.mazworx.com/store/?...ct=2506krf150 wrote:ok...first...yes i searched.....2 yes i looked in the camshaft megathread....and put a post but noone replied....ok...heres my setup and i want to know if i need to run 272s or 264s...ive 272s in my hands...do i need to ship them back and get 264s???
Greddy Intake maniFull race top mountGT3076rbc valves, springs, and retainerseagle rodscp pistons
Whats your opinion on the solid lifters? i hear its impossible to set clearancesILikeMy240sx wrote:if your car is going to be a drag car or a highway queen then Id put 270s. If you are going to do any kind of road racing then Id use 260s.
well most people make their power under 8k rpms....so why go any higher than 8... thats barely higher than stock...White Comet wrote:cuz sr's dont like high rpms 9even redline, not overrevving) and solid lifters will help control any valve float
Big cams require stiffer valve springs, and when you increase the seat pressure you increase the pressure on the hydraulic lash adjusters... you should be able to see where this is going judging from your other posts, but the short story is they can collapse, then rocker arms start to fall off or with rocker arm stoppers, break.06krf150 wrote:ok so it's 264/264...thats what i had been leaning towards all along but i just wanted to get some reassurance... but since im not going with a monster cam then why is it necessary to go with the solid lifters???
