HKS wastegate actuator on stok redtop , is it safe?
mallbor240SR
Car: 240sx 1990
did anybody install one of those on a stok engine?i read they are rated at 12psi and also heard they are adjustable, but i dont know if it will increase or decrease the boost,( higher or lower than 12psi)im planning on upgrading my t25 to a gt28r but right know i dont have money to upgrade injectors and maf so i was wondering if installing the hks actuator with the gt28r will be safe on a stock engine.
180fan
Car: 89 fastback
yes, even at 7 psi, you won't leak like the stock actuator does. good stuff.
mallbor240SR
Car: 240sx 1990
you mean I can adjust the hks actuator to 7 psi?thats great thendo you think i should increase my fuel pressure since ill be running a bigger turbo?thank you
mallbor240SR
Car: 240sx 1990
anybody?
AuburnRyan
Car: '93 Hatch
I use it and run at 14psi, stock injectors and maf. Holds very steady. You can adjust to the boost you want assuming you have a boost gauge. all you do is turn the screw, and test...
driftsil40
Car: 240sx
I ran a ltye model ball bearing t28 on my car and a gtir t28 on my friends. we are both on stock injectors and maf's. I have a tuned ecu and he is stock. if you go over 12psi I hope you have a metal head gasket. at 12psi though it should be ok, you may want to bump a couple psi of fuel pressure. on all stock motor at 18psi you need about 60psi at idle.
highmilehatch
Going over 12 psi doesn't necessitate having a metal head gasket. You need larger injectors and a good tune (Power FC, Enthalpy). No need to run that kind of high fuel pressure.
mallbor240SR
Car: 240sx 1990
im not planning on going over 12psi of boost , im just wandering if the hks wastegate can be set to stock boost 7psi, so i can use it for now untill i get bigger injectors and z32 MAF sensor
kane2g
Car: 92 240sx 95 240sx
yesthats where I had it for a while.
mallbor240SR
Car: 240sx 1990
thas great thank you all
