onosqv »
https://forums.nicoclub.com/onosqv-u507.html
Thu Jun 30, 2005 8:42 am
It's been a while since I hooked mine up so I could be wrong, but I think it's the brown wire w/ black tracer.
O, and another thing I remembered from hooking up my friends.
An easier (less starter killing) way to test your timer:
1) instead of starting the car everytime, just put it into "on".
Here the constant & ignition wire should be powered. If ignition is not powered... well, you got the wrong adapter.
2) turn it to acc or off.
The timer will start counting down - and of course your engine is off.
Use a multimeter to check the constant & ignition wire (only really need to do ignition, but just in case).
If they are powered, then your timer should be working right and now you can do the real test. If not, then poo on u, haha.
