HKS Turbo Timer TYPE I or II
Got13oost
Car: Kouki S13
Hi guys i got a problem with installing the turbo timer. got any site's that are useful, think i got a type 1 orr 2 its like light purplish color.. and do i need a harness or i can do it jus splicing wires and connecting.???
Nicksemianiw
Car: JDM 89 Silvia K's
You can solder them togeather red to red white to white green to green etc. But thats ALWYAS a paint in the *** and can hurt Buy COLD HEAT LOL! but anyway a harness will be much more easy just plug in and have fun.
SR20Drif
Car: 1992 Nissan 240sx
I have never heard of an HKS Type-II but if its the HKS type-1 its basicly the same. I have a HKS Type-0.
You should get the wiring harness for it if u want to pay the extra, but if your going to splice into the ignition (which is what i "HAD" to do) then heres the wiring diagram:
Red Goes to 12v ConstantGreen goes to 12v Only when the key is turned to the on positionBlue is 12v accessoryGrey connects the the parking brake wire
(everything should work from there but if u have a brown wire it goes to the RPM signal from your ECU. its the yellow red wire only on the SR20DET ECU)
(If you have a extra blue wire also then that goes to the SPEED signal from your ECU. Its the yellow green wire from the SR20DET ECU ONLY)
Thats that. Find a place to put it and test it out. Also make sure you disconnect your negative terminal from the battery when connecting the wires.
Got13oost
Car: Kouki S13
Seems pretty hard, well ima jus give it a try if i cant figure it out i think ima have to buy a harness, and by the way what color is the cluster of type 0 and Type I?? anyways thanks for the help
kane2g
Car: 92 240sx 95 240sx
Got13oost wrote:Seems pretty hard, well ima jus give it a try if i cant figure it out i think ima have to buy a harness, and by the way what color is the cluster of type 0 and Type I?? anyways thanks for the help
6wires is the type0i think type1 has 7
