HKS Turbo Timer + RB25 speed sensor = MPH instead of KPH ???
300Plus
Car: 1995 S14 w/ Rb25det Series II
I swapped the r33 cluster in my s14 and it reads correctly ...in KPH. I was looking at buying a HKS turbo timer which has the speed read out in MPH and was wondering if I could do something to make the signal read correctly in MPH. I doubt the turbo timer would be able to automatically adjust the signal given out by the speed sensor into MPH, or would it?
I've scene and read a thread about making the Skyline cluster read in MPH but what I'm wondering is can I add a resistor in the speed sensor wire that goes to the turbo timer, to make it read in MPH correctly?
anyone running the hks type 1 ?
Thanks for the help guys
gawdzilla
Car: none
should be fine. just like how the stock s14 speedo is fine in mph using the rb25 sender
