HKS TURBO TIMER QUESTIONS....NEED HELP!
RBpoweredSileighty
There are 3 diferent HKS Turbo Timers that im looking at...
i got this info off of http://www.mvpmotorsports.com/...shtml#
which is a products seller on here.
First one is HKS Turbo Timer Type 0
specs: ITEM # HK 4101-RA009
This silver turbo timer features regular timer characteristics as well as a voltage meter for your battery. It also features automatic shutdown based on driving characteristics, 1-touch 1 minute shutdown, 1-touch 3 minute shutdown, & regular manual shutdown selectable between 1-10 minutes. Blue LCD back-lighting / Red flashing LCD warning and countdown function.
PRICE: $85.00
the second one is
HKS Turbo Timer Type 1 - Silver Japanese Spec
secs: ITEM # HK 4101-RA011
This silver turbo timer features regular timer characteristics and many more such as: 1. Vehicle Speed / Speed peak hold display function; 2. Vehicle Speed warning function; 3. Engine rpm / rpm peak hold display function; 4. Engine rpm warning function, setting able to be made in 2 points (shift up indicator / red line indicator); 5. Distance / Time: Acceleration measurement: 0-100m, 0-200m, 0-400m & Section time: 200-400m& Speed attain time: 0-100km/h, 0-150km/h, 0-200km/h& Acceleration time: 50-100km/h, 100-150km/h & Auto start and manual start function; 6. Stopwatch measurement: Time measurement; Multiple Lap time measurement; 4 digit display for the measurement time / 0.01sec display; Large 40mm x 9mm liquid crystal display panel - Blue LCD back-lighting / Red flashing LCD warning and countdown function; Large capacity relay: 25A (Other manufacturers are 15A);Safety network will detect parking brake condition, and stop the timer for safety reasons.
PRICE: $109.00
now i got this info off of http://store.240sxmotoring.com
this one has a diferent display
i would prefer to get the amber color display since i am wanting to match the color of the gauges i plan on running.
my questions is.... which one is better? and both these sellers are listed on the forum is there a member discount?
for anyone who can answer these questions it would be most helpfull, thanx in advance..
rico05
Car: 1992 RMS13 w/ CA18DET
I have the E-01 (the one that has the accelerometer, etc) #1) Great unit! It is the starting point of my still raging HKS fettish. #2) The display is blue when the car is running, but either during warning mode (RPM, Voltage, Speed, etc) or during shut off countdown it will blink red. Spot of advice: get the subharness...saves about 2 hours of soldering/rewiring under the dash. Turns 15 connections into 3 splices.
RBpoweredSileighty
so the E-01 would be the second one i listed? that would be the Jap Spec right with all the extra stuff? and yes i will be getting the harness for it.
RBpoweredSileighty
anyone else?
justmerging
Car: 07 Versa SL w/CVT Cuz I'm lazy
I have the type 1 black case us measurment. Awesome unit. You don't have it listed but you can get it from overboost.com I think it was like $135 for the timer and harness.
rico05
I guess it is the Japanese version one that I have. I got if from a guy in Thailand so it may be. O here is another tip: like I said, I got mine from overseas and the instructions I got with it were in Japanese. I had to pay $13 to HKS USA to get them to fax me a copy of the english instructions. If you like, I can fax them to you for no charge if you need them.
RBpoweredSileighty
justmerging wrote:I have the type 1 black case us measurment. Awesome unit. You don't have it listed but you can get it from overboost.com I think it was like $135 for the timer and harness.
well the silver one is an option also black. so it has the extra features on that model?
RBpoweredSileighty
rico05 wrote:I guess it is the Japanese version one that I have. I got if from a guy in Thailand so it may be. O here is another tip: like I said, I got mine from overseas and the instructions I got with it were in Japanese. I had to pay $13 to HKS USA to get them to fax me a copy of the english instructions. If you like, I can fax them to you for no charge if you need them.
ok then thats the one i was thinking you where saying... "J SPEC"
yes if you could fax me the info that would be very nice. give me your email so i can give you my office fax #.
RBpoweredSileighty
well i decided to get the HKS turbo timer type 0
thanx to all who helped out in this thread.
