HKS Turbo timer problems, HELP!
K240
Car: 1993 240sx
Hey everyone, I have a 1993 240sx, I am installing my HKS Type 1 turbo timer, and i have everything wired up except the Brown wire (RPM signal wire). I am trying to figure out which wire the brown one splices into on the ECU...Trust me I searched EVERYWHERE! Any help will be appreciated, Thanks in advance.
nissanfanatic
Car: 1992 Nissan 240sx SE
Coudl get it from the tachometer. Click here
That will show you where to get it from the ECU.
Florida240sx
K240
Car: 1993 240sx
Thank you very much for the help, but I wired my Turbo timer into that yellow w/ red striped wire, and I didnt get a reading....I made sure it was a solid connection too...Any possibilities?
K240
Car: 1993 240sx
Bump bishes!
Import_Ant
K240 wrote:Thank you very much for the help, but I wired my Turbo timer into that yellow w/ red striped wire, and I didnt get a reading....I made sure it was a solid connection too...Any possibilities?
that should be the right one, I wonder what voltage the stock tach puts out.
http://www.hksusa.com/info/download.asp?id=1634#
this might be the issue. 4299-Ra004 HKS tach converter
you should be able to verify what voltage that wire is putting out w/ any decent voltmeter.
Modified by Import_Ant at 1:59 AM 9/13/2005
2_Liter_Turbo
Car: _________________
'96 S14 Coupe: SR20VET
'90 R32 TH1 GTR: RB26DETT
'92 S13 Fastback: SR20DET
'11 V36 Sedan: VQ25HR
'06 GMT800 2500HD: LBZ Duramax
I am installing one also, but I can't figure out what the white wire comming out of the car harness is for?
K240
Car: 1993 240sx
Damn i guess i need to go buy a voltmeter, but, in the meantime, does anyone else know what voltage this wire is putting out?
K240
Car: 1993 240sx
BTW, this is on a KA24DE ECU, so the HKS website was no help, I just didnt want it to be mistaken as a SR ECu...wait , I just remembered that im in the KA-T section of course you guys realize it is a KADE ECU...whoops =]
Import_Ant
I'd check mine but I'm running SOHC so I dont think the info would do you any good
K240
Car: 1993 240sx
Dont worry about it, thanks for the help! does any one else know?
K240
Car: 1993 240sx
Bump!
