HKS Super AFR - which ECU pins?
chickentendah
Car: SR20DET Hatch
I need to install a HKS Super AFR with my Redtop SR. If you have installed yours without problems, which ECU pins i.e. wires are we supposed to use?
And yes, I have the manual that came with the AFR, but it didn't come with SR20DET specific instructions.
Here's a reference to the ECU pinshttp://sr20det.nismo.org/srtech.htmAnd here's the manualhttp://www.hksusa.com/content/pdf1632.pdf
I have the "62" ECU.
Thanks.
GTS4-R
Car: my feet
well if u have the pin info and the harness wire info from the unit....u have what u need......
