you really should not run any larger cams w/o a tune.
I would highly recommend you read the camshaft mega thread...all of it
zerothread/210484Thats what i did before i chose my cams.
i would suggest maybe a 256/264 combo with a 2871. It all depends what you are going to do with the car, cams change your powerband alot. if your drifting you need torque to come in sooner, so you use a shorter duration. whereas if your drag racing you want maximum high end power so you would go with a longer duration and higher lift. You should also match your cams to your turbo, if your dragging you dont want to slam a 272 in with your t25 just because your drag racing.
this is all explained in the mega thread, do your research, deside what you will be doing with the car and chose your cams.
