driftin_sr20det »
https://forums.nicoclub.com/driftin-sr20det-u33183.html
Fri May 26, 2006 5:35 pm
I don't quite understand why the idles acting soo crappy. Install went perfect, took around an hour. But, its acting real lopey. At 1K rpm's its got 14 or less vacuum. Doesn't seem right. They work great through the band, but idle sucks. They are supposed to not affect the idle that much, I thought. I've had them lying in my closet for probably around 5 months and just decided to put them in since I had some time with the holiday weekend. I've tried adjusting the IACV and the idle screw, but the best I can get it is about 17 on the vacuum at a 1400 rpm idle. If anybody has some suggestions or idea's let me know. Timing is on by the way.
Oh by the way, I'm running a s13 redtop w/ gt28rs; FMIC, 255lph pump, topspeed intake manifold, SSAC exhaust manifold, divoced dump, 3" full exhaust, MBC @ 1 Bar
