hokiruu »
https://forums.nicoclub.com/hokiruu-u3429.html
Fri Jan 30, 2004 6:52 pm
I know exactly what you are talking about. It gets even more confusing when you have three different preprogrammed boost channels. sorry if this sounds like a rant, but I have been dealing with the same concerns for months now. The truth is, from my experience and everyone i have talked to, most BOVs will flutter at some point (either high boost or a gentle deceleration) regardless of how they are adjusted. This is not necessarily compressor surge! mine sounded like it was coming from the intake, not BOV, but i could still feel the air being discharged from the BOV with my hand after an idle rev. the important thing is that you have it adjusted tight enough so that it doesn't leak under high boost. if it is leaking under high boost, your car will bog really hard, around 4500 rpm. although it wont always sound like a clean, simple, 'whoosh", your turbo is not going to die. i have mine adjusted now so that it goes a clean "whoosh" shifting from 1st to second, and higher gears have a slight flutter, and this is how many people say is normal.here's how to adjust it:loosen the nut on the spring adjustment allen bolt on the back of the BOV so that you can adjust the bolt with your fingers. screw it out. screw it back in until you feel the resistance from the spring loaded piston. the use an allen key to adjust it about 1-3 turns, depending on how how much boost you are running. if it leaks (you will be able to hear and feel it), tighten it a bit. you want to find that sweet spot where it holds just enough not to leak, but still discharges. it may still flutter at this point, bit that's okay. if i'm wrong, and i blow my turbo, i'll be sure to let you know. but this is the best i have been able to come up with through hours of trial and error an talking to people.
