http://www.takakaira.com/asp/t...cat=2
here it is. you get 12 rpm points at 200rpm intervals. It also has a knock sensor and a warning mode to tell you if you're knocking.
DISPLAYThe new Super AFC-II utilizes a state of the art visual display lighting called Vacuum Flourescent Display (VFD) to provide a bright & clear visual information. A new dot matrix monitor enabled a variety of information to be displayed simultaneously where the driver can check quickly. Information relayed can be either displayed numerically (analog gauge style) or graphically.
BODYThe body of this new product is slimmer & smaller (H52 mm x W126 mm x D18 mm) than the previous offerring. This ergonomically designed body houses only a "center button" which toggles & rotates where it enables the driver to navigate (4-axis toggle: up& down, and left & right) and to select functions of the Super AFC-II. This button also has a feature that enables the driver to fine tune any parameters. All these features in the new model's user interface made it much easier & efficient compared to the older model. KNOCKING MONITORThe new Super AFC-II has a new knock sensor function which alerts the driver. This ensures that the engine is tuned to perfection at every stage. This function only works on vehicles that has an engine knock sensor.
MEMORIZE 2 TYPE OF SETTING DATAThe new Super AFC-II can save two data setting from data collected with respected to air flow adjust rate, throttle duration, engine RPM, etc. The driver could use these two settings in a variety of driving conditions, be it track, street, or just plain cruising.
PASSWORDTo avoid the new Super AFC-II from tampering by unauthorized users, a password can be set for protection.
WARNINGThe driver can set up various warning functions inorder to monitor the engine operation. These functions includes incoming air flow rate, suction pipe pressure, engine knock RPM, etc.
OthersSettings & data stored in the new Super AFC-II will not be lost even if the it is disconnected from the vehicle battery power.RMP signal for air flow & pressor sensors can be adjusted in 12 points in 1% increments depending on fuel settings in +50% to -50%. Or the RSP can be set in increments of 200 RPM. Throttle opening duration: Adjustable by size.
INSTALLATION For installation, connecting to 6 sensors such as the air flow signal, the throttle sensor, the rotary signal, ignition and the knock sensor. Comparation of Super AFC to Super AFC-II Previous Suer AFC New SUPER AFC-II Air Flow Setting choose 8point choose 12point Air Flow Engine RPM every 500rpm every 200rpm Drive Voltage Circuit Safety None more stable Display Monitor Adjustment None setting up display (air flow/pressure) Display Color Blue Standard model:BlueLimited Edtion:White Other Functions None -Knocking Monitor-Digital Display-Setting Memory function-Warning function-Password-Lock function Limited Edition- Production made 1000pcs only solely for Japan domestic market . Rare and hard to find outside Japan. Stock release date from Apex will be End of Jan. Reserved Order is accept now.
And it's only $311. Japan only for now but it should work fine on US cars I would assume since it's universal.
