I'm currently running 3.5psi on with only a Walbro fuel pump, but plan on turning it up to 8-10 with this AFR and my 370cc injectors. I just installed my new S-AFR. I ran into a problem, the MAFS acts like its unpluged and only goes to 3000rpm. If I plug the wire that I taped into back together, it works just fine. Although it wont adjust without the air flow signal. Has anyone out there hooked up a HKS S-AFR to a KA24DET? please let me know how you tapped into the MAFS signal...
Thanks.
