HKS Recirculation Help!?
NateDogg
Hey Guys,
I have a HKS SSQV that I got from fiz..I'm trying to convert it to run recirculated but I cannot figure out how to get that damn purple insert out of there so I can put the recirc fitting in..
Please help!
The All Mighty KA-T
Car: 1995 Eclipse GS-T
Sorry ( Off Topic ) but where did you get the recirculate kit from.....i'm needing one for mine? And how much did you pay?
NateDogg
Got it all from Fiz..I am pretty sure mvpmotorsports carries it.
sxseguy
Car: Makin' it go faster!
You have to disassemble the entire thing by taking off all of the allen bolts at the rear that holds the two halves together.
You might as well buy a recirc fitting to replace the purple one before you do it, if you haven't bought one already.
NateDogg
Nevermind...there is a gasket that has to be removed on the upper portion. I thought all of the bolts came out with the gasket through the bottom but there are 4 which are held up with flanges...Damnit. I called HKS and the girl there is probably laughin her balls off at me..
Modified by NateDogg at 10:07 AM 5/26/2006
Modified by NateDogg at 10:17 AM 5/26/2006
