GraySilvia »
https://forums.nicoclub.com/graysilvia-u3605.html
Mon Nov 03, 2003 12:01 pm
Well, the problem with 87mm pistons is if you want to bore the block to 1mm over, you take the nikasil cylinder liner off with it. So you need to beg and plead and do all you can to keep the nikasil liner or you can sleeve the block OR have it recoated with nikasil. Neither one of those last two options are cheap. I think the service limit on the nikasil liner is .008", or .2mm? If memory serves me correctly anyway. So, have a reputable engine shop (machine/build shop) take a look at it and see if a hone of <.008" will be sufficient to clean up the cylinders. Hopefully you can just hone it and be done.
Also, nikasil should be DIAMOND honed, not carbide honed. Carbide honing makes for inferior oil retention properties. Just FYI. I hope some of this helps.
