HKS Manifold W Megan or Tomei Elbow
MES14AN
Car: "97" 240sx "88" Acura Legend
So i recently pick up an Hks manifold and now im in the market for a either tomei or megan turbo elbow to mate up with it, this will be going on the megan dp i had already btw. The price difference between the two is only 45 bux(leaning toward tomei) but I also want to avoid any pita fitment or clearance issues i might get by picking the tomei mated with this setup.
Sugar
Car: S13 w/ Sr
So what did you make this thread for?
MES14AN
Well the purpose is to compare the megan vs tomei design cuz I know there are fitment problems with different manifolds and dp's when brands are mix matched with turbo ext. also my ride has a 2" drop and lil worried about scraping too. im running bottom mount gt2540 turbo if that matters.
So do you have experience with it?
MES14AN
Scored the elbow already. someone close this please..thanks
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
We don't close threads. We just leave them open for further discussion. An example of a good reason is let's say you hook all this up, and you have fitment issues, OR if it fits great, either way, you can come back and share your experience. Now anyone else that uses the search feature and types in "hks manifold tomei elbow" will find this, and have their answer.
MES14AN
Hey good point i didnt mean to sound stubborn, aftermarket parts with picky applications can get a muthaxxxxxx frustrated. Ill keep everyone updated
when install goes thru...Im going to meditate and use the force now.....
PyR0NiAk
MES14AN wrote: use the force now.....
That's what she said. ;)
MES14AN
Haaa thats dirty...but you meant it in a good way right. :chuckle:
PyR0NiAk
Of course, I did.
