Post by adrianfromthecastle » https://forums.nicoclub.com/adrianfromthecastle-u30128.html Tue May 30, 2006 11:33 am
Post by Bronze MFP » https://forums.nicoclub.com/bronze-mfp-u7726.html Thu Jun 01, 2006 4:37 am
Post by adrianfromthecastle » https://forums.nicoclub.com/adrianfromthecastle-u30128.html Thu Jun 01, 2006 6:35 am
bushings are shot, but it isnt that noise, i know that noise pretty well, and it isnt that.Bronze MFP wrote:are your tension rod bushings shot? thos will knock, other than that just check to make sure all the suspension bits are bolted to the car like they should... also check the exhaust, if you have a flex section, it might alow it to knock the underside of the car if your ehaust hangers are old and worn
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
