HKS GT2835 vs GReddy TD06
SR180SX
Sup guys, which turbo is better for SR? HKS GT2835 or GReddy TD06 turbo?
Nismo_Freak
Car: 89 Nissan 240SX
HKS utilizes a dual ball bearing design and utilizes a Garret Turbo. Greddy uses a Mitsubishi Turbo. I would go with the GT2835 cause I know they are built well and spool quickly.
Daunttless
how much power do you want to make?
SR180SX
350rwhp hopefully...
SR180SX
by the way, what's best A/F and trim size for SR motor?
Daunttless
you mean A/R??
If you want a GT2835, I'd go with Greaser and say 56 trim compressor wheel in the T04E housing and a 90 trim turbine wheel with a .86 A/R Housing.
Nismo_Freak
Aka... a GT2835R turbo ... and they come in a .87 A/R housing :) just to ninja your post heheheh. Either way the A/R is there to help you fine tune the turbo. If you want a faster spool-up and good midrange then go with a lower A/R such as a .61 or .73. If you want a better flowing housing with top end power and a bit more lag then get the larger 1.01 or 1.12. Dauntless made a wise choice in sticking with the moderate A/R which will be the better street turbo.
Daunttless
you whore, but, in a good way. : )
nissandet240
Car: My car, DJ sytem, PC's and Technology
how much power does the HKS will support and the greddy mentioned will support, @ what Boss .
