esetreceCA18DET wrote:i have this setup on a car.... std engine, ported & polished head, custom exhaust manifold, 3 inch dpipe & exhaust, fmic , hks gt2530 w/t3 exhaust flange , mines vx rom std cam timing& std ignition timing, boost set to 13lbs the question is .. I get full boost at 4000 is there something wrong? is there any way to get it to spool up any quicker??the exhaust housing has a t3 flange & .64 a/r If i swap to a .64 a/r with a t25 flange may i get faster spool up???thx a lot for your help
The answer to your spooling question is "No"! The CA18DET does not produce enough CFM to get that turbo with that A/R to spool any faster. Besides that, 4000rpm spool-up is normal with the CA and any T3 based turbo. Unfortunately, if you want the turbo to spool-up any faster than that, you'll have to either raise the compression which isn't worth the gains or simply look at another hairdryer. How fast are you looking for full boost?
Dee
