ceniack wrote:i have a lead on one of these used for 600 bucks, and was curious if it would fit on the stock manifold (as far as clearance goes), and if i would need new oil and coolant lines, also, i will be running 450cc injectors, bout how much boost would i be able to run safely with this turbo, and then finally, anyone willing to make me a bin file i can burn to a chip for 450c injectors, z32 maf, and this turbo.
it is rated for ~320hp
Depending on your cash flow I'd suggest investing in an EPROM emulator like the Romulator or any of the other ones and burning your own chip.
I have a CA w/ 450 dsms and a Z32 MAF and it took a lot of work to make it run properly, simply loading live edit, setting the injectors to 450 and the maf to Z32 didn't work.
