J-Spec Tuner wrote:If your using E-manage you shouldn't have to have your ECU retuned, as its perfectly capable of running up to 900cc+ injectors off the stock ECU.
have you your self done this? and if so how cause i would kinda like to go this route. however, as turbo and chris said things get "weird" and it may be easier to jsut get a retune......
s13sr20chris wrote:i just looked at the gtrs again(its been a while) and realized the turbine is the same while the compressor is almost the same(just a difference of wheel trim option).
i didn't even realize this while i was reading about the 2. but i have a question. if the 2 are almost identical why is the gt28 rated at a max hp of 340rwhp while they claim the hks turbo can be taken up to 400rwhp? is it jsut a more efficent design?
