zombieslider wrote:nobody has experience with this?
also its for an s12 ca18det so the wiring is the same for any other ca18det right, sorry for the newb question?
Negative. The CA18DET uses the NP-12 harness, the CA18ET uses the NP-4 one. The NP-4 plugs into L20 and L28s with the ECCS system.
The CA18 uses the following four chips;E683 NormalE684 Full turbine kit with intercooler. The kit turbo was a 50 trim T4E686 T-3 turboE683V Normal turbo and VPC
The CA18ET ROM chip is the E104. This chip is also used on the Z18ET.
Enough of the history lesson, this gear is ancient and best left on display, not actually running an engine.
