HKS exhaust manifold burning side mount hose
skirodeo7
Car: 2007 Nissan Frontier, 1991 Nissan 240sx
Anyone know of a solution to this? The factory rubber hose is getting super heated from the exhaust manifold and is literally crumbling apart. Thought about wrapping the manifold with heat wrap, and getting a silicone hose, but not sure if either or both would solve the problem. A metal hotpipe wouldn't really solve it either since it would still require a silicone coupler from the hot pipe to the compressor outlet.
anyone else have this problem?
Modified by skirodeo7 at 4:55 PM 12/16/2008
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
you can either wrap the header and reduce temps (and life) of your header.....or go front mount which is the best idea because it will cool your air temps...i guess you could wrap the elbow on your smic too
skirodeo7
would a silicone hose stand up to the heat?
japslapsilvia
Car: 90 s-13
i use some cheap (4ply) silicone egay hose, and was using an egay HKS copy manifold, and didnt have any problems.
nzmoman
Car: 240sx 2 of em' and always lookin for more
im not having any issues on mine either and Im using a silicone coupler to an aluminum hotpipe and a megan SS manifold.
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
I've got a HKS metal hotpipe with the provided silicon coupler on and I haven't had any problems with heat on the coupler. Silicon may be the way to go.
skirodeo7
nice! sounds like silicone is the way to go. thanks guys!
