HKS EIDS type H1 works.
2hunglo1standhi
Car: 1990 240sx XE Coupe KA24E-T
1990 240sx SE Fastback KA24E N/A
Recently i have got a HKS EIDS H1, just to see if it worked on a KA24E-T to vent to atmosphere a Blow off valve, install was simple, wire it up following the ECU pin out and instructions (solder/heatshrink). Settings were adjusted from the factory, however a minor adjustment was needed to the cut off time screw, prolonging it... After?...... No stalling, No backfires, and for all the Rice in the world, a loud annoying pshhhhheeeerrrrrrr from the NGR Type S BOV!
I do not recommend venting Blow off valves, Cops target it... and car runs (not as good as it re-circulated) unless you know what your doing or running Blow Tru, MAP, or Various other proper set ups, this was merely just to see how it compared to the SAFC and if it worked, and it did. DUH! Runs perfectly fine but re-circ would run much better....
WDRacing
Thanks for posting your results.
