hks cams...
just brandon
Car: working on cars & the gf
i was lookin at enjukuracing.com the other day. and i noticed that they had the hks cams. now what i want to know...since i know nothing about cams *yet* i was wondering...whats the different degrees for?what are the different stages for?
ItzGenX
Car: Smoke Purple 95' S14.5. Powered by the "Iron Man".
The different stages is for the lift (how much the valve is pushed open). The duration in degrees is how long the valves stay open. Lift is good for some power gains due to more air coming in throughout the powerband. Duration is good for top end and high revving power, but some loss in low end due to valve overlap (if duration is excessive).
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
Just some more info for ya, Step 1 is good with nothing more than a RAS kit, the step 2 takes valve springs and retainers, the stage 3 is a PITA and takes solid lifters.
256 is a good drift cam (great response and idle)264 good all around (slight lump and slightly soggy bottom end)272 topend cam, must have a big turbo to make this work IMHO
Paul
chillmieste
Car: 97 240sx KA-T
So is it better to get both intake and exhaust cams the same size or different sizes?
ItzGenX
I thought step 2 only required valve springs. Retainers is an optional thing.
IvanS13
Car: *** & Titties
chillmieste wrote:So is it better to get both intake and exhaust cams the same size or different sizes?
For use with upgraded turbo's... DSM cats are liking the 264 intake - 272 exhaust setup.
I H8 UR DSM
IvanS13 wrote:For use with upgraded turbo's... DSM cats are liking the 262 intake - 272 exhaust setup.
um, no...they are 'liking' the 272/272
[GoaTSLonG]
I have the step 2 264intake 272 exhaust on a stock t-25 it does make the power band weird but the gains are defiantly noticeable. I can't wait to feel them with my GT30R i just ordered .
ImportIntelligence
Car: Big turbo's :)
Get RAS, even with stock cams the rocker arms like to go flying!
chillmieste
Car: 97 240sx KA-T
I have a full t3 turbo upgrade, would it be better to go 272/272 or the 262/272? I dont really know about these things, but I would like to upgrade my cams and have the best setup as possible.
Thanks,
Charlie
GTS4-R
Car: my feet
I have a t3/t4E setup goin in and I have the cams, RAS, Springs, headgasket, studs, and intake mani goin in all together.....they're HKS 264's step 1 on both I and E.....I'll let you know how they work out in march/april. I went with the 264's to avoid stalling at lights and cause they're pretty much good all around in an SR
GTS4-R
Car: my feet
chillmieste wrote:I have a full t3 turbo upgrade, would it be better to go 272/272 or the 262/272? I dont really know about these things, but I would like to upgrade my cams and have the best setup as possible.
Thanks,
Charlie
If u stagger the I and E cams you'll want to get Cam Gears also so U can tune the car correctly....I stayed away from the stagger because I don't think the cam gears are worth the extra 3-5 HP..... (maybe 10 if ur lucky)......and the extra $$ it'll cost on the dyno to get those 5-10 ponies.......just my input......little easier not goin staggered....
turboex
do you have to have the solid lifters for the stage 3?
I H8 UR DSM
hks lash killer kit.
GTS4-R
Car: my feet
Tomei also makes a solid lifter conversion but I would take hydralic lifters over solid any day of the week......the tomei kit can be purchased on http://www.jspec.com
chillmieste
Car: 97 240sx KA-T
I already have hks cam gears I got when I purchased the motor(lucky me:)) I have stock cams though. When I plan on buliding the head I was wondering what stage and what type of cams to use. I have no clue what would be the best setup, thats why im asking you guys. Im done building the bottom end forged wiseco pistons and eagle rods. Im want to do the head but just not sure what type of cams to get.
