float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Wed Jan 31, 2007 8:03 pm
As previously stated, I believe the shim's on most lifters is between the valve and the lifter.
I would like it if someone would come up with a KA24DE style lifter. The problem with the tomei style is that the cam has to be removed to set the cam to lifter spacing, whereas on the KA24DE, the shims are on TOP of the lifter. This allows you to check the clearance, order the correct sized shims, depress the lifter with the cam still in, remove the old shim, install the new shim, and repeat.
I also don't like that the tomei solid lifter doesn't utilize the cam oiling that the hydro lifter does.
I'm sure tomie wouldn't have done this if they hadn't researched it and decided it wasn't an issue, but it would still be nice to have.
