Postby
two40splease »
https://forums.nicoclub.com/two40splease-u86663.htmlThu May 07, 2009 11:07 am
I just purchased a brand new Hks ssqv. The problem is it leaks air from where it normally discharges when its idling causing me to run rich. When I remove the vacuum line it stops leaking however. Has anyone else experienced this problem??
Postby
two40splease »
https://forums.nicoclub.com/two40splease-u86663.htmlSat May 09, 2009 9:33 am
I really don't need to if the valve operated as advertised (sealing at idle) I can tune for it. As a matter of fact i took it apart played with it and i believe if the spring is stretched a bit it seals better at idle. There is no screw adjustment on this one.
