mello88 »
https://forums.nicoclub.com/mello88-u18450.html
Thu Feb 09, 2006 9:16 am
Great response here, thanks for all the input. I'm glad to know I'm not the only one with this divider wall crack!
Carl H, thank you for commenting in my thread, I just wish your post were a little more helpful . This is my first turbo build and I'd really like to hear your input, I've read your posts on this board and others and respect your advice.
I have read a few books and studied SAU and many RB forums for some time for info on my build. My goals for the RB20 are 2-2.2bar with ~300ish rwhp, with a 7500 limit. Motor has adj cam gear, fmic, 3" turbo back, 500cc's, z32 and PFC on stock internals to support this power. Now, if my math is right it looks like the RB20 should flow 30-35lb/min @ 7500rpm with 2-2.2bar.
When I plot the lb/min curve onto the gt28rs comp map it looks like the it will support the flow, and offer a quick spool and nice midrange.
Edit: I forgot to mention that I am also considering the gt2871r and gt2876r, would the 76r be more suitable for my application? Midrange torque and quick spool time are more important to me than peak hp. On the same note, I have no idea which turbine A/R to go with; .64 or .86 -- which do you suggest for the little rb20 on say a 2871 or 2876?
Thanks for your insight
Modified by mello88 at 4:22 PM 2/9/2006
