Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Sun Jun 27, 2004 1:32 pm
boost controllers can tend to be "off" on their calculations due to the hose length and if it uses fuzzy logic or not. The actuator would offer a more consistent boost since it's not having it's line intercepted. For a real boost controller, go with an electronic controller. They will open the wastegate at the penultimate moment allowing for a bit more response whereas a traditional controller leaks into place (as the boost goes up, the WG slowly opens allowing some gasses by that could be used to spool up faster).
I would personally go with the Profec over the HKS unit just because it's less of a hassle to change boost settings. With the HKS unit, I have to drive the car, find its peak boost, get out, wait for the engine to cool, change the WG arm length, drive the car, repeat.
Both types of boost controll can transfer to other turbos. as long as the bracket on the HKS unit lines up to the mounting holes, you're golden
