NeedCAforS13 »
https://forums.nicoclub.com/needcafors13-u4234.html
Fri Oct 21, 2005 6:53 am
from the horsham develpments website: one of their test cars...
The stage 2 chip is designed to optimise the fuelling and ignition for an S13 with the following modifications:
Free flow air filter Free flow exhaust 16psi boost pressure Uprated intercooler T28 turbo from an S14 200SX Uprated fuel pump The chip removes the fuel cut and, in conjunction with the upgrades above, will allow the engine to produce up to 270bhp.
The stage 2 chip instructs the ECU to deliver more fuel to the engine under high boost. It also retards the ignition a little more than the stage 1 chip. This prevents detonation when running high boost levels.
mods:Stage 2 chip T28 @ 14psi of boost Saab front mount intercooler K & N filter Mongoose exhaust Bosch fuel pump
The graph shows power at the wheels (blue), power lost through the transmission and tyres (green) and calculated power at the flywheel. This car made 264bhp @ only 14psi of boost, the increase in performance comes from the modifications to the engine. More power could be liberated with a higher flow intercooler and more boost pressure. The Stage 2 chip optimises fuelling and ignition timing to take best advantage of the modifications.
they're running stock maf and injectors. I have this chip, and 10psi feels sick.
Sean
