Yes that info is necessary if I were deciding which cam brand to get, but since I already have the HKS step 1 I'm wondering if there would be any benefit from the step 2. Are lash adjusters the same as lash killers? I saw the HKS lash killers but I didn't think they were necessary for a mild build.Geno750 wrote:Information like the turbo, exhaust manifold, intake manifold, desired rev limit, and lash adjustment system would help answer your question.
To just throw out a random answer, BC264(step 2) cams with solid lash adjusters are a party.
Mild build which uses what parts, do like this guy said and we'll answer you.CMG wrote:Yes that info is necessary if I were deciding which cam brand to get, but since I already have the HKS step 1 I'm wondering if there would be any benefit from the step 2. Are lash adjusters the same as lash killers? I saw the HKS lash killers but I didn't think they were necessary for a mild build.
Also, brand... wtf? no. Lift, duration = what matters, brand just happens to who makes the ideal cams for your application.garagelu wrote:dude do you not understand, brand has nothing to do with it. It depends on your turbo setup. Tell us your turbo size and that would help us help you. With a small t25 you would stay with a step one and anything bigger like a 2871r or bigger you want step 2 especially for more top end power.
And you cant just look at the lift....duration also matters. give us more information on your setup!!!
do you not know how to read? I said brand has nothing to do with it. Read the posts above. They were talking something about brand of cams which is stupid. Im not stupid. I know that lift and duration matters. thats why I said the same thing you did in my post.Geno750 wrote:
I probably don't understand. The reason I didn't give my set up is because I was talking about the future, I didn't want to be talking fantasy. The only parts I've accumulated so far for a rebuild are the Greddy valve springs, and HKS cams. If I could I'd do a full build, but since that costs alot I plan on doing springs, retainers, cams, and head gasket with a T28 or something like that. I'm still in the planning stages. I'm just wondering if I should stick with the step 1 that I have or ditch em and go for step 2.garagelu wrote:dude do you not understand, brand has nothing to do with it. It depends on your turbo setup. Tell us your turbo size and that would help us help you. With a small t25 you would stay with a step one and anything bigger like a 2871r or bigger you want step 2 especially for more top end power.
