We are having issues with maintaining the idle with the car due to a miss.
The idle was jumping but seemed to want to hover around 600 rpm when the timing via the distributer was set with a good amount of retard.
This is what we began working with.
I looked over most of the IACV vacuum lines and we cleaned the IACV as well. We found a few cracked ends but nothing was leaking according to our highly technological water spray method lol
I ran down the list of components and he had replaced just about all of them ranging from ignition components (plugs, wires, dist. cap, rotor), 02 sensor, MAF, TPS, etc. The only components I could come up with that could cause a miss are the timing, fuel pressure regulator, vacuum or intake leak, plug gap, plug choice, and the EGR.
No vacuum leaks detected but I do hear a faint hiss that is intermittant; sounds similar to a vacuum leak.
Car has the miss even at ~3000rpms.
When we advanced the timing the miss got worse, and the idle was raised 100-150 rpm. Timing set at a slight advance, car ran better at higher RPM according to owner.
We plan to replace the fuel pressure regulator because the car has a hesitation on start-up and blows black smoke (fuel) out the exhaust. This possibly could be the source of our vacuum leak as well, because without vacuum the FPR is gonna run full pressure.
I know I'm kinda vague but I'm trying to fill you in on everything.
