Import_Ant »
https://forums.nicoclub.com/import-ant-u16968.html
Tue Sep 19, 2006 3:14 pm
I had this very same problem, car would hit the rev limiter at 5,200 in gear, out of gear, any gear, didnt matter.
Turned out I had a short in my 5th gear position sensor wiring and the ECU thought I was constantly in 5th gear, I snipped my speedo sensor, 4th gear, and 5th gear position sensor wires at the ECU to get rid of the governer altogether and it's been fine ever since. just pull a pinout diagram, try snipping the 5th gear position sensor to test and trying to pass the 5,2k limit in first or second gear. I dont like revving my motor that high without a load on it but you're welcome to try that too.
