Li’l Truckie making a few edits to the post up front as even I get confused sometimes.
Bear with me if you will. As I was researching your interchangeable parts question for Conner, I pulled out my 520 manual to verify condenser capacity. They are both the same, but will not work as they are constructed differently. E1 is inside the cap and the J13 is outside. I think the screw-connecting tab is different on both so you cannot put the J13 condenser in the E1's Hitachi distributor or the E1 condenser in the J13. They will be backwards on the E1, upside down on the J13, and the wires will not reach.
However, that is not all I discovered.
So here is what I did wrong. Based on the 320 manual I always thought the J13 distributor was manufactured by Mitsubishi as it strongly resemble the Mitsubishi distributor in the 320 manual (see schematics on Flickr). Well that is incorrect. The distributor on the J13 is in fact a Hitachi Model D411-53. The distributor model on the E1, in the pics posted by Conner, and the one pictured on the left in the photos is the Hitachi D406-01 (this I knew). As far as the Mitsubishi distributor on the E1, no change, I have never seen one. Parts manual says it exists; however, the repair manual makes absolutely no mention of the Mitsubishi distributor.
So other than mis-identify the J13’s Hitachi D411-53 for a Mitsubishi model everything remains the same. No change to any of the issues this thread is addressing, hard to find parts, misidentified parts, incorrect parts listing, and just how confusing this distributor thread really is, which I just proved. And absolutely no change to the objective – Identifying the correct parts and part numbers for the Hitachi D406-01 and where to get them.
Everything below has been updated and should be correct, so on with the show!
Li'l Truckie here and I am ready to tackle the ever-confusing Hitachi distributor project. For many PL-320 fans and early Datsun owners who have sedan's with the E or E-1 series engine this is a confusing topic and rightly so. Over the next couple of post we are going to rebuild the Hitachi D406-01 Distributor that is found in the Datsun E and E-1 Series Engine (note 1). With the amount of research we are conducting this will truly be a graduate level course in research, patients, and parts compatibility verification. So get ready for some heuristic learning with Li'l Truckie.
Pictured below are the Hitachi D406-1 from the E1 (now and forever on the left) and the Hitachi D411-53 from the J13 (now and forever on the right). Please note the particular shape of the distributor bodies. The Hitachi D406-1 is all steel and rounded off at the bottom, while the Hitachi D411-53 is white metal (die-cast zinc, or tootsie toy pot metal) that is straight with clearly defined steps in the outer body. Even though the Hitachi D411-53 distributor pictured is from a J13 the outer body is almost identical to that of the Mitsubishi for the E-1. So this is a quick way to determine which distributor you have. Again, more than like you have the Hitachi D406-1. If by chance you have the pictured Hitachi D411-53 distributor on your E-1, be advised this is not original, sorry.
I have also posted more pictures to my Flickr account and you can view them here -
http://www.flickr.com/photos/113742723@ ... 610710483/
Okay, so why is this Hitachi D411-53 distributor from the J13 in our project. Simple, its a parts issue. Many vendors on eBay and your local parts stores have misidentified Hitachi D411-53 parts as compatible with the Hitachi D406-01. They are not, period end of story. Okay, not quite the end of the story as we still have to discuss the parts issue. I am not putting down eBay vendors or your local parts stores; they do not know any better.
Case in point. Of the two auto parts stores I visited to order points, condenser, cap, and rotor in support of the project (proof of principle), both stores listed the Hitachi D411-53 rotor as the correct rotor for the Hitachi D406-01 Well that is just doesn't work.
Ahh...so you ask what about the correct rotor? I'm currently working this issue. With the help of the sale clerk, we looked at the pictures (yip, we looked at pictures) in the catalog and order 3 different rotors that looked close. These should be in Friday or Saturday. Yes, you can occasionally find the correct rotor on eBay, but one of the objectives of this thread is to correctly identify all necessary parts and part numbers so you can walk into your home town auto parts store and order everything you need. But we are not there yet. Okay, so you are tracking the rotor issue.
Distributor Cap - Ugh....Okay. NAPA does have the correct E-1 distributor cap listed in its online catalogue. Manufactured by Echlin, the part number is ECH, EP306. Relax, no need to hop in the car so fast. It's on back order and not available. I ask the clerk what "back order" means and he said he would make a few calls the next day. Kudos to the clerk for tracking this down and giving me an update, but after making some calls to higher, we still could not define what "back order" means.
Practicing what I preach I took the Echlin part number to O'Reilly's and they cross-referenced the part to a BorgWarner part # C501. Not so fast, relax. According to the sales clerk, I ordered the last one from some warehouse in Southern California. It should be here the middle of next week. So not looking good for a distributor cap.
Points and condenser - these should already be in and I just need to brave the weather and icy roads and get into KCKS and pick them up. Are they the right parts? We'll find out tomorrow around lunch.
So that's where we are at with this project. We have ordered the "last" distributor cap in the entire USofA, identified the wrong rotor (not our fault), but we're trying to find one, and we are waiting to pick up the points and condenser to verify they are the correct parts. So cross your fingers and if your 320 or E-1 engine runs leave it alone....it's not broke so don't worry about fixing it just yet.
Okay, give me a day or two and I'll strip down the Hitachi 406-01 distributor, paint it up all nice (if it warms up a little), and find the rebuild kit and other parts that you have already identified as missing from the pictured Hitachi 406-01distributor. I'll take some pics along the way, draw up a nice diagram on power point and not something on a used index card with smell good water soluble marker.
Thanks,
Li'l Truckie
Notes-
1- Per the parts manual the was both a Hitachi and Mitsubishi distributor for the E and E-1 Engine. However, I have never run across the Mitsubishi Distributor as picture in the parts manual in any 320 or early Datsun with the E-1 engine. If you have the E-1 with Mitsubishi Distributor please let us know. We would like to get some pics for future reference.
