matttail »
https://forums.nicoclub.com/matttail-u50105.html
Sun Nov 16, 2008 7:37 pm
I don't remember their proper name, but I believe those are you balancing weights. When you tires were last balanced they use small weights attached to the wheel to make the tires "even". Looks like you may have popped one of those off. You may well be OK without it, but you should be able to get a tire shop to balance your tires for you for $5-10 per tire.
