Hit rev limit, car shut off and now wont start? HELP ASAP!
Twoforty_sxy
Ok i hit my rev limit in 2nd. My car competely shut off and it wont start.
When i crank it, it goes "brrr brrrr.........brrr.....brr" it cranks a couple times, then pauses, then cranks some more.
I have air, and spark, i have fuel at my fuel filter.
I had a diagnosis from nissan, they said my timing chain fell off or broke. It was $1100 to fix with 8 hr labor.
I took it home to start taking it apart and i removed the valve cover and the chain was fine.
I played with my CAS back and forth a bit and got it from "crank crank..pause...crank" to a steady cranking.
I removed my fuel pump fuse, and it didnt sound any different when i cranked it.
Any ideas?
NISTECH
do a compression test. post your results.
