Hit a curb *Update*
spankme234
Car: 1991 q45
well my Q is running again 900 dollars later. I had to replace pretty much every thing connected to the wheel including suspension except the brakes. Parts were 500 and 400 for labor. He bought alot of the parts from a junk yard, which actually look alot better then what was on there. I also had my brake pads replaced. When this was done my mechanic realized that my rear driver tire caliper was stuck down. Which caused the pad to wear faster. Would this be an easy switch of a caliper or is their more involved?
911/Q45
Car: 1990 Infiniti Q45
1996 Porsche Turbo
Should just be a caliper swap and flush the lines well.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
And lubricate the pins this time!
Jeff Williams
Car: 1994 Infiniti Q45t
2000 Infiniti I30t
2004 Infiniti M45
71, 72, 73, 82 & 2000 Corvettes
maxnix wrote:And lubricate the pins this time!
ABSOLUTELY! Most stick, because cheap brake shops only pull one pin, to swing the caliper away and install the new pads. Then they don't put caliper grease (Specifically formulated for high temps) on the pins. It took me several tries to get my LR caliper to stop burning up the outer pads. Once the grease is gone, and brake dust has dried in the hole, it is a bear to clean it out and get new grease in there.
