Hello
Ive got a green auto light flashing and car in limp mode.... i can clear these using a basic code clearing scan tool and the car then runs and drives as it should.
However,once the engine is stopped and the key removed, then turn the key back to II the faults reappear.
Im seeing fault codes relating to the injectors,the injectors are working as they should once i clear the faults.... any clues as to whats causing this and help solving this would be greatly appreciated.
Ive checked everything i can using the Nissan service workflow and a multimeter,all check out ok.
I have seen possible cures as being the earth wire behind the ABS actuator or even the alternator being an after market type thats not producing the correct voltage....checked both of these out as ok.
Ive also had the C1130 code and ive made sure the dpf pipe is clear and ive changed the sensor... this fault still appears.
Please help .... its soul destroying
