HashiriyaS14 »
https://forums.nicoclub.com/hashiriyas14-u11745.html
Tue May 10, 2005 2:19 am
This started up a couple of days ago. Generally it only happens at fairly high speed (<70mph), and then when I hit the brakes enough, it goes away. It has started at lower speed once or twice though.
I both searched and asked some people, and I've gotten the following suggestions:
-Tension Rod-Wheel bearings-Something brake-related-Fuel Pump (don't think this is it, as it doesn't happen at idle at all)
Any other ideas? How would I go about finding out for sure? Just get the car up on Jackstands, take the wheel off, disassemble brakes, etc.., and just keep going until I find the problem? if it's something like wheel bearings, will I even be able to see the problem?
Also, how big a deal do people think this is? Could it be really bad to drive on it? Is something catastrophic going to happen if I continue to drive on it?
Thanks.
EDIT: Car Info: 1998 S14 5spd, 78k miles. Only maintenance done recently was clutch master/slave cylinders. DC Metro area.
Modified by HashiriyaS14 at 1:49 PM 5/10/2005
