konatown »
https://forums.nicoclub.com/konatown-u45732.html
Mon Dec 24, 2007 9:59 am
You need to replace your Fuel Pump and Fuel Pump Control Unit.
Fairly common problem. Could die on you at any moment, spend a couple hundred dollars to buy new and a spend a few hours on a weekend to swap them out.
There's loads of information on this if you use the 'Search' function.
EDIT:
Sorry, wrote that preemptively. I see your other post you list as a 2003 Q45. My advice was for the first generation Q45, but could be something similar.
Also put your information about the vehicle in your profile so it shows under your name, like mine to the left.
